noleafclover133
Apr 13, 2013Aspirant
Adding Drives to RN104
I just picked up the RN104. I started with 2x 3TB Seagate drives. They built the volume (which took a solid 24 hours) and are in RAID 1 / X-RAID. I then added another formatted 3TB drive (same mo...
mdgm-ntgr
Apr 13, 2013NETGEAR Employee Retired
NTFS would mean one partition unless you deleted the partition after you formatted it to use NTFS.
