bcaouette85
Jun 27, 2015Aspirant
Adding hd slow
I just added my 3rd 4tb drive to my 316. It's run a day and a half and the rebuild is only half way. Is it normal to take 3 days each time I add a new drive before I can access the additional storage?...
vandermerwe
Jun 28, 2015Master
No.
What firmware are you running?
Do you have a backup?
Are all the disks' smart data ok?
Do you have an encrypted volume?
I would let it run to completion, then power down your nas, remove the disks, label them according to slot number, then test them all using vendor tools extended tests.
