Aous94
Dec 19, 2018Follower
Adding more disk didnt increase my capacity
Hello, I was using my ReadyNas with 2 x 4TB WD Red drives, working on RAID 0.
i was planning to expand my storage and ordered a 12 TB Ironwolf Drive.
i added the 12TB to the array, then forma...
- Dec 20, 2018
Hi Aous94
Welcome to the Community!
Adding a disk on a Flex-RAID RAID 0 setup will convert it to RAID 5 to add protection to your data. The reason why you still have 8TB of data is because of the unused space (8TB), this is due to the disks you already have (4TB) which limits you to this capacity since it's the smallest volume you have.
If you have a single volume, changing to X-RAID should not affect your data and will auto expand your volume. You will not be able to turn it on if it's not on single volume RAID.
It would be best to backup your data before changing to X-RAID and finish syncing first.
Another method is to destroy the volume and create a new one using X-RAID. Again, backup is always advised. You can go to page 38 using this manual
Hope this helps!
Regards
Marc_V
Dec 20, 2018NETGEAR Employee Retired
Hi Aous94
Hope this helps!
Regards
