MikeDK
Feb 17, 2017Aspirant
Admin page forgot username and password. RAIDar show ReadyNAS drive, but will not browse anymore.
Problem: I changed internet companies, therefore router about a week ago. After the change, whenever i want to browse the ReadyNAS network drive, i click on "Browse" in RAIDar, but it just goes s...
mdgm-ntgr
Feb 18, 2017NETGEAR Employee Retired
Is the NAS I.P. in the same range as that for your new router or in the range for the old router?
Have you tried an OS Re-install yet (this will reset some network settings and the admin password)?
MikeDK
Feb 19, 2017Aspirant
I have no idea if the NAS I.P is in the same range, and no i have not tried it?
But what is the username for the admin page login? Cause if the password is something standard like "admin" then it would still be the same, as i have never changed it, since i got the NAS???
But please advice on how to do an OS Re-install, as this might help me out?
- SandsharkFeb 19, 2017Sensei
The admin name is just "admin" (lower case) and the default password is "password" for the newer systems and "netgear1" for older.
- StephenBFeb 20, 2017Guru - Experienced User
MikeDK wrote:
I have no idea if the NAS I.P is in the same range...
mdgm-ntgr is asking because this problem usually happens when
- users assign a static IP address to their ReadyNAS (for instance 192.168.0.x)
- they change ISPs later on and end up with a new router that uses a different address range (for instance 192.168.1.x)
If you did this, then the OS reinstall procedure will fix it. If you just forgot the admin password, then it will reset that too (as explained by Sandshark)
- MikeDKFeb 22, 2017Aspirant
Ok thank you... Actually thanks to all of you.
In some magic way, RAIDar works now, and when i click browse, it actually goes into an explorer window that browses the ReadyNAS, not my PC. I have no idea why, i have been away from home for a couple of days in which it has been turned off due to the power being out for a brief period, but other than that no changes has been made.
I have tried logging in to the admin page, it does not work with the default admin username, and "password" or "netgear1" as password.
I will probably try the OS reinstall, because with that i will be able to use the admin page again.
But thank you, and have a nice day, u all have been great!
