Matt69
Feb 03, 2017Aspirant
Admin Page is Offline + System volume 'root' usage is 100 %
Hi, For some days, I can no access at my configuration web page. I have the web page : We are running firmware 6.4.1 My ReadyNAS is used as like a files server. I always have ...
Feb 06, 2017Guru - Experienced User
There could be some files "under" one of the mount points - /home or /apps for instance. It is possible to remount them, so you can examine those folders.
To see what's underneath you'd enter
mount --bind / /mnt
Then look in /mnt/home, etc
When done,
umount /mnt
Matt69
Feb 07, 2017Aspirant
Congratulation StephenB ! Thank you so much for your help ! !
In /mnt , I had the folder restore/backupdata/document/.... . I removed it and it's great, now.
But the configuration web page does'nt working. Do you have any idea for this ?
