Al555
Jan 31, 2019Aspirant
Admin page offline - RN214 after installing PHPSysInfo
Had the 214 for awhile, been working great. Saw the update for firmware 6.9.5 and updated, no problems after.
Made the mistake of installing PHPSysInfo and now the Admin page is not working. ...
- Feb 08, 2019
Hi Al555,
The OS of the NAS was not completely installed. L3 has manually upgraded the firmware on your NAS. The issue should be resolved already. The NAS has been booted to Normal mode already.
Al555
Feb 01, 2019Aspirant
PM sent! Thanks JohnCM_S.
JohnCM_S
Feb 02, 2019NETGEAR Employee Retired
Hi Al555,
Thank you for providing the logs. By the way, are you getting any error message when trying to access the admin page? What is the status of the NAS on RAIDar?
- Al555Feb 02, 2019Aspirant
Hi JohnCM_S,
Admin page shows ERR_CONNECTION_REFUSED
RAIDar status - Healthy
Diagnostics show no errors found in both system and logs
- JohnCM_SFeb 07, 2019NETGEAR Employee Retired
Hi Al555,
I saw something on the logs that the HTTP apache server is going to safe mode which means that there is bad apache2 config somewhere. We will need to have remote access to your unit so we can further check and probably fix it. Can you boot the NAS in Tech Support? You may check this link for the steps on how you can access the boot menu and select Tech Support. You may just PM me the 5-digit code afterwards.
- Al555Feb 07, 2019Aspirant
Hi JohnCM_S,
Thanks for following up, PM sent!.
