Starlionblue
Sep 14, 2010Aspirant
AFP "connection failed"
Hiya, Did a customer install a few months ago with: - ReadyNAS Duo. - Seagate FreeAgent backup drive. - Buffalo WZR-HP-G300N routers. - iMac - Thinkpad Duo has both CIFS and AFP on. The iMa...
Starlionblue
Sep 15, 2010Aspirant
sphardy wrote: So you cannot connect at all to the Duo over AFP - with any username/password? And you have no entries at all in the keychain related to the Duo? What if you enabel guest access to a share - can you access that over AFP?
Correct.
Guest access throws the same error.
