Starlionblue
Sep 14, 2010Aspirant
AFP "connection failed"
Hiya, Did a customer install a few months ago with: - ReadyNAS Duo. - Seagate FreeAgent backup drive. - Buffalo WZR-HP-G300N routers. - iMac - Thinkpad Duo has both CIFS and AFP on. The iMa...
Starlionblue
Sep 15, 2010Aspirant
sphardy wrote:
Starlionblue wrote: Correct.
Guest access throws the same error.
Then you need to contact tech support - something is fundamentally wrong so maybe they can login and take a look
Yeah. I hope they can see something from the logs. Unfortunately the customer is waaaaaaaay out in the boonies and it's a major pain in the bum-bum to get out there.
