jszatmary
Dec 04, 2008Aspirant
AFP Mount Point Permissions (Solved)
I have the following situation on Leopard 10.5.5: % mkdir a % ls -ld a drwxr-xr-x 2 User staff 68 Dec 4 21:53 a % mount_afp afp://User:password@readynas/Share % ls-ld a drwx------@ 9 User ...
jszatmary
Dec 08, 2008Aspirant
The problem is not with the files inside the share, but the mount-point itself. If you look a the first example, you'll see that the mount-point I'm using is "a" and starts out with 755. Once I mount afp://readynas/Share over it, the permission on "a" becomes 700 and there's no way to change it. The files inside the share (and inside the mount point) continue to have the correct permissions and work as expected. The problem seems to be with the mount point itself. I PM-ed you...
