jszatmary
Dec 04, 2008Aspirant
AFP Mount Point Permissions (Solved)
I have the following situation on Leopard 10.5.5: % mkdir a % ls -ld a drwxr-xr-x 2 User staff 68 Dec 4 21:53 a % mount_afp afp://User:password@readynas/Share % ls-ld a drwx------@ 9 User ...
jszatmary
Dec 08, 2008Aspirant
I agree that this should be the correct behavior... however this is not what happens under Linux (Ubuntu.) Under that environment, when tested a mount of an SMB share to the ReadyNAS, the permissions became 777.
Anyway back to the correct behavior... If this is correct, as it should be according to spec, how can I modify the permission on the ReadyNAS share (the source of the permissions that cover the mount-point) so that they are reflected as 755.
What I noticed is that if i modify the "everyone" permission under Advanced Options, it actually maps to the user bits at the mount-point level. That is, if on the ReadyNAS share settings I change the everyone permissions to "read" (from the default read/write) and then mount the share, the mount-point permissions become 500, instead of 700. This would indicate that there is some mapping of permissions taking place between the ReadyNAS and the host system.
By default the group/everyone perms under Advanced are read/write for both. This is obviously not refelcted on the mount point, and is confusing. Why would the ReadyNAS interface show read/write for all three sets of perms under Advanced, but when mounted, would show only 700?
So the questions remains, can I create/configure a share on the ReadyNAS that will mount as 755 via AFP?
