jszatmary's avatar
jszatmary
AFP Mount Point Permissions (Solved)
I have the following situation on Leopard 10.5.5:
% mkdir a
% ls -ld a
drwxr-xr-x 2 User staff 68 Dec 4 21:53 a
% mount_afp afp://User:password@readynas/Share
% ls-ld a
drwx------@ 9 User staff 264 Dec 4 21:54 a
% ls -l a/*
drwxr-xr-x@ 4 User staff 264 Dec 4 11:56 a/Stuff
% chmod go+rx a
% ls -ld a
The behavior is identical when mounting through Finder or AppleScript or Automator etc.
So, the permissions on the mount point start out correctly, but after the mount only the user has any access. And, trying to change it afterward (which would be an issue anyway since it would require some hacks during boot/login) does not work. This is a problem because the web server cannot access the share. The files inside the mount have correct permissions.
Is there a way to change the default mount point permissions? From where are these permissions inherited? Are they coming from ReadyNAS or is it a mount behavior? Can either the ReadyNAS share or mount behavior be modified to provide group and world read/execute permissions on the share?
Thanks,
John
  • The subject has "Solved" in it, but I don't see a real solution.
    I didn't exactly fix the 700 permission problem, but I could change the user by hooking mount_afp:
    sudo -i
    mv /sbin/mount_afp /sbin/mount_afp2
    vi /sbin/mount_afp
    : #!/bin/sh
    : sudo -u darkfader ${0}2 $@
    chmod +x /sbin/mount_afp
    Result:
    ls -l /Volumes/Resources
    total 0
    drwx------ 191 darkfader staff 6450 Feb 6 01:08 download
    That's good enough for me.
    Tip: if you have a username+password in the map file, change that file's perm to 600 to protect it.
ProSupport for Business
