Aaronius
Dec 30, 2024Aspirant
after hot swapping a dead drive, no volumes available? RN104
Hi all, I need a little help. I hope this is an easy one to fix here's the story so far: ReadyNAS RN104, (system version 6.10.3) reported a failing drive, which then became a dead drive. The...
Dec 30, 2024Guru - Experienced User
Aaronius wrote:
if anyone has advice on approaching them, I would love to hear that also.
If you like, I can take a look at the logs. Download the full log zip, and then put it into cloud storage (Dropbox, google drive, etc). Send me a private message (PM) using the envelope link in the upper right hand of the forum page. Include a download link to the log zip - making sure the permissions are set so anyone with the link can download the logs.
Aaronius
Hi there, PM sent.
Many thanks indeed. 🙂
