phyd
Feb 03, 2013Aspirant
All connectivity dies every 24-48 hours on ReadyNAS Pro 6
I have an unusual problem with my ReadyNAS Pro 6 (4.2.22), which has only started happening the last couple of weeks. About every 24-48 hours the ethernet connection dies completely. The box looks l...
phyd
Feb 10, 2013Aspirant
Looks like there's still issues. Lost connectivity overnight, and the front panel wouldn't even respond (other than to completely power-off and reboot). Found masses of junk in syslog. Example --
Feb 10 08:03:29 machinename kernel: >WARNImsg+0g bug 43D D5DD r5D04449 flcomm: rnted: P Trace:
Feb 10 08:03:29 machinename kernel: 50
Feb 10 08:03:29 machinename kernel: [<mon+0x8b/0x/0x70
Feb 10 08:03:29 machinename kernel: [<0
Feb 10 08:03:29 machinename kernel: [<fffffffx20
Feb 10 08:03:29 machinename kernel: [<0x30
Feb 10 08:03:29 machinename kernel: [0x33/0x40
Feb 10 08:03:29 machinename kernel: [<fffffx8bd/0xb5073/0x90
Feb 10 08:03:29 machinename kernel: <4150
Feb 10 08:03:29 machinename kernel: [<ffffffff884> [<ffffffff880fffffff8803> [<ffffffff88050
Feb 10 08:03:29 machinename kernel: [<ffff170
Feb 10 08:03:29 machinename kernel: [<f90
Feb 10 08:03:29 machinename kernel: [<fffff0x0/0x5
Feb 10 08:03:29 machinename kernel: ---[ end trace 400afb3762881696 ]---
Feb 10 08:03:29 machinename kernel: ---------t net/xb50(pied D0443DvnxD040
Feb 10 08:03:29 machinename kernel: Modul Tainte W 2. [<ffffffffffffff880c0
Feb 10 08:03:29 machinename kernel: [<ff<ffffffff880fffff88002bce>]fffffff885ffffffff884> [<ffffffff884fb18d<4> [<fffff [<ffffffffffffff882c2763>] ? ff880ae251>] do90d4>] ? t
Feb 10 08:03:29 machinename kernel: ------------[ cut htcp.c:ardwa3D seqt D549
Feb 10 08:03:29 machinename kernel: <4s linked .37.6.RNx884fb18d>] 32b>] warffffff880bd034459>] warce>] ? apic_tim4531>] ? bb253>] ? ff884fb18d>] tcp_recfff88518ae3884b
Feb 10 08:03:29 machinename kernel: ------------[ cut here ]----tcp_rece: To443D rfl 0
Feb 10 08:03:29 machinename kernel: Mod li: nv6gpio 2.6.37_64.2.4 #? tcp_recvslowpath_dc0>] ? polrn_slowpath__timer_interrupaw_spin_loock_sock_n] tcp_recvmsg+0x8bd/0>] inet_r
Feb 10 08:03:29 machinename kernel: [<ead+0xd1/0x110
<DIED HERE>
Similar messages in kern.log. Looks like connectivity was lost a few hours earlier. Here's netatalk.log --
Feb 10 01:48:18.562871 afpd[28607] {socket.c:157} (E:AFPDaemon): read: Connection reset by peer
message repeated 6 times
Feb 10 01:48:18.562937 afpd[28607] {dsi_stream.c:421} (E:DSI): dsi_stream_read: len:-1, Connection reset by peer
Feb 10 01:48:18.562963 afpd[28607] {dsi_stream.c:250} (N:DSI): dsi_disconnect: entering disconnected state
Really bizarre stuff, no idea what is causing the machine to go down every few days. Any ideas on where else I can investigate?
<DIED HERE>
