Tripline
Sep 15, 2016Apprentice
allow anonymous users?
ReadyNAS 2120 v2 you can select the Allow anonymous access check box to allow anonymous access to the shared folder. In this situation, users are not required to provide their account credentials wh...
Tripline
If File Access in the GUI is superceded by the NTFS permissions, then I guess that would make things easier. I would not have to worry about the Everyone checked box in the web GUI then?
JennC
Sep 15, 2016NETGEAR Employee Retired
Hello Tripline,
I believe Network Access should always be set to Everyone so NAS will just pass the all the permissions on to the Win server.
- TriplineSep 15, 2016Apprentice
So NAS permissions does matter, and it depends if the permissions get overwritten on the NTFS side.
