markfarr's avatar
markfarr
Amazon Drive Unavailable in Admin - Cloud Settings Console
Hello,
I know my NAS is EOL, but I am running Raidar 6.9.3 on it, and I am hoping someone can help me figure out my problem.
In January of this year, I configured my ReadyNAS to upload and sync with Amazon cloud drive successfully.
Today, I went to double check my sync settings, and I noticed that the "Amazon Drive" button is now in an "OFF" position, which I did not set.  When I try to enable it, I cannot move the button.  All other cloud services are accessible for configuration.
Interestingly, I also noticed that I am unable to check for updates from the System Overview landing page.  An error message appears that states "Cannot connect. Communication error. Check your Internet connection, DNS Settings, or proxy settings."
I feel the two problems are probably related.
Now I know the major change I did not my home network is that I enabled IPv6 internally.  But eth0 still has all its IPv4 settings.  I also confirmed from a SSH Session that I can ping out to the internet on IPv4 and IPv6 successfully.
I have also confirmed that name resolution is working for IPv4 and IPv6.
My questions are:
1) Is this related to IPv6?  doing a lookup of Amazon.ca returns only IPv4 addresses.
2) could someone share the URL that the "Check for Update" link connects to?
If anyone can help, I would be very appreciative.
Thank you
Mark.
  • StephenB's avatar
    The obvious thing to try is to disable ipv6, and see if the problem resolves.
    Have you done that?
    • markfarr's avatar
      markfarr
      Hi StephenB, thank you for replying quickly.
      To be completely honest, I did not know I could disable IPv6.
      I have done that now, and rebooted my NAS, and I am now able to check for updates again and I do see that the Amazon Cloud App and settings are back functioning again.  So we have confirmed the root cause of my issue.
      So is this a problem with the Amazon cloud app?  Addressing the NAS over IPv6 works well so I know the NAS OS is ready for IPv6.
      • StephenB's avatar
        IMO it is (it should fail over to IPv4 if IPv6 fails to connect).
        mdgm-ntgr, could you make sure that this is entered as a bug for development to look into?
ProSupport for Business
