thrix
Mar 21, 2015Aspirant
Another gMail Alert question
Hello, I have a problem to send alert to multiple mail adress. I've read lots of topics but i can't find the answer. Here is my configuration : Adress mail used to send alert : adress1@gmail....
Mar 21, 2015Guru - Experienced User
Well, your problem isn't related to the gmail settings, otherwise test 1 and test 2 would have failed. And the "from" address is gmail, so the kb article you are linking to isn't relevant.
The problem is that the option to send alerts to multiple email addresses isn't working. The separator should be space (http://kb.netgear.com/app/answers/detai ... -system%3F), which is what you are using.
What firmware are you running on the NAS?
