chsu83
Mar 31, 2017Luminary
Antivir - Settings
What I've seen is that with the Addon you had the possibility to make settings to Antivirus. But in the integrated this is not possible? And the addon is not anymore available for 6.6.1 What I need...
- Apr 04, 2017
chsu83 wrote:
I've in mind it wasn't also on 6.6.x ...
Perhaps there is someone who nows, if there is a plan to get it back. Otherwise I'll do create an idea exchange entry.
It was removed when Netgear switched to ClamAV antivirus (early January).
It wouldn't hurt to create an idea exchange entry.
FramerV
Apr 03, 2017NETGEAR Employee Retired
chsu83
Apr 04, 2017Luminary
I'm not shure if its the correct way, when there was already a Antivirus Plus - where you could to the settings. Perhaps it is already planned to move that up to 6.7?
- StephenBApr 04, 2017Guru - Experienced User
Unfortunately it is not part of 6.7.
- chsu83Apr 04, 2017Luminary
