ashfakjs
Nov 14, 2021Guide
Antivirus disabling Automatically
Dear All, I’m facing Antivirus issue with the Netgear NAs device, Model Readynas 428 Point 1. Antivirus not getting auto update, I have to update it manually by running freshclam –v command Poi...
JeraldM
Nov 18, 2021NETGEAR Employee Retired
Hi ashfakjs,
Assuming that you've already rebooted the NAS and enabled it again but it's still the same issue, please upload it to a file-sharing site then send me the download link via private message.
The system logs can be downloaded on System > Logs.
JeraldM
NETGEAR Community Team
- ashfakjsNov 21, 2021Guide
Dear Jerald,
Thank you for your replay, YesI have restarted NAS device but still facing same issue. every time Antivirus is getting disabled and antivirus databas also not getting update automatically. All the time i have to SSH NAS device and need to run freshclam command to update antivirus database.
I'm unable to attached Log files here as attachment as it is Zip folder.
Kind Reagrds
Ashfak
- StephenBNov 21, 2021Guru - Experienced User
You shouldn't post the log zip publicly, as there is some privacy leakage when you do that.
JeraldM is asking you to send them via private message (PM). Click on the envelope icon in the upper right of the forum page to do that.
Also, he asked that you upload the zip file to cloud storage (google drive, dropbox, etx), and send him a download link. That works around the issue with attaching a zip file.
- peterongleyNov 22, 2021Guide
I also have this happening. After having all the error messages regarding the non uploading of antivirus definitions due to the need to install the latest firmware, this has been the next glitch to appear. With help from this forum, (Thanks StephenB) I was able to manually update my system firmware to 6.10.6 the system was able to successfully download virus definition updates. Then a few days ago I got two system messages in the log files that seemed to indicate that the whole antivirus mechanism had been remotely shut down, with no explanation given.
Nov 19, 2021 09:34:46 PM System: Service protocol anti-virus-sche-scan is disabled. Nov 19, 2021 09:34:45 PM System: Service protocol Antivirus is disabled.
