klausn
Jan 26, 2017Tutor
Antivirus scanner how to manage after upgrading to 6.6.1
Hi, Does anyone know what the next problem is? After upgrading to Firmware 6.6.1 I can't manage the Antivirus scanner. Before upgrading I could change the frequences of updating the Antivirus sc...
- Jan 27, 2017
Hi great you give me the link...... many txs
aalexandrebeta
Jan 27, 2017Master
The way to use the built in anti vrus is for me a bit blury and hard to understand too!
For me I turned it on, then the unit downloaded the app, then it updated the virus files and then it went green and a shield appeared on the unit.
Jan 27, 2017Guru - Experienced User
For right now the only controls are "on" and "off".
I think that's a huge problem, hopefully there will be more options soon.
