klausn
Jan 26, 2017Tutor
Antivirus scanner how to manage after upgrading to 6.6.1
Hi, Does anyone know what the next problem is? After upgrading to Firmware 6.6.1 I can't manage the Antivirus scanner. Before upgrading I could change the frequences of updating the Antivirus sc...
- Jan 27, 2017
Hi great you give me the link...... many txs
Jan 27, 2017Guru - Experienced User
For right now the only controls are "on" and "off".
I think that's a huge problem, hopefully there will be more options soon.
klausn
Jan 27, 2017Tutor
Hi,
I read a lot and could not find anything about it.
The programm is still running and updating, but managing or seen in my App isn't possible.
The Antivisus App is disappeared............
:smileysurprised:
- StephenBJan 27, 2017Guru - Experienced User
Correct. It wasn't compatible with the new package, so the upgrade uninstalled it.
Your only option right now is to turn it off on the system->settings page.
- klausnJan 27, 2017Tutor
Hi StephenB,
Thanks and I found it!
I switched it off as you told me.
Hi,
I checked my NAS and seems:
RNDP400U (ReadyNAS Ultra 4 Plus) – READYNAS ULTRA 4 PLUS (DISKLESS)
Model / Version: RNDP400UEnd of Life (Service Unavailable)
But the system is still in really good condition and full operational. (of course with disks)
I got this problem after the last OS update!
As you likely know by now, Netgear switched to a completely different AV package in 6.6.1.Many people are having issues, even on new OS 6 NAS.
Again, right now you can (a) leave the service running, and be prepared for some issues, or (b) turn the service off on the system->settings page. Netgear isn't giving you any other choices right now.
Well thanks for so far...!
