PHolder
May 25, 2017Aspirant
Any plans for Samba fix for CVE-2017-7494 ?
I posted elsewhere about this, but CVE-2017-7494 NEEDs to be patched on any device still in operation, and I think that includes the older, technically out of support models that I have 6 of. Wit...
- May 30, 2017
Legacy Sparc, x86 and ARM firmware is now available:
RAIDiator-4.1.16 (Sparc)
ciarpame
May 29, 2017Tutor
We've built firmware with the patch for CVE-2017-7494 for legacy models as well. Once they have undergone QA testing, I believe we plan to release those updates as well
Do you have an ETA?
As for SMB2 and SMB3, we're not updating to a newer samba series on the legacy models at this time so SMB2 support would remain experimental and remain disabled. The new firmware has the same samba version except with the patch so the netgearx at the end (where x is a number) would be incremented by one to reflect the change.
Does it mean that on my Readynas NV+v2 there is a buried disabled SMB2 I can enable by myself in some way via Putty? Can you point me to some helpful resource to do it? Side effects? Thank you
mdgm-ntgr
May 30, 2017NETGEAR Employee Retired
