dannieboiz
Oct 02, 2014Tutor
Anyone got 6.2 on their legacy RN yet?
Didn't see any post on this topic, do you install 6.1 from the other thread then just upgrade from frontview?
- CharlesRGuide
dannieboiz wrote: At this point, it really doesn't matter if NG will officially support OS6 on legacy RN as long as there's a way.
I disagree. Corporate isn't going to use OS 6 because "there's a way" Even most of the consumer market is going to stay away. I have sold quite a few of the older units and in virtually every case I had to uninstall OS 6 and install OS 4 per their request... they wouldn't purchase it other wise.
Personally, I have zero issue with them dropping the older hardware and I'm sure there is some logic behind it. Interface wise OS 6 is light years ahead however at times it's too cute for its own good. At times I end up clicking my mouse over an image and hoping an option or two will pop up! CharlesR wrote: dannieboiz wrote: At this point, it really doesn't matter if NG will officially support OS6 on legacy RN as long as there's a way.
There are two folds to this. For myself, it is a PITA to have to jump through hoops to get things running but at the end of the day, I purchased my 4200 at an extremely good price so the little effort to bring it up to speed is ok. But when I spec out new product for my work, I look for one that works just out of the box. Last run, we installed RN dou v2 at 60 sites. We're getting to replace them all and no one said anything about NG but instead they're looking at Synology and QNAP. I haven't used a QNAP before but I'm pushing for Synology because a simple thing as joining the NAS to the domain requires a "Business Class" RN while any Synology can be joined to a domain. That's already a winning factor especially when we refresh hardware everything 3-4 years. We're actually replacing the NG early, at only 2.5 years because of the failure rates on these things. Nothing major but every few weeks, we find ourselves fixing something at least one of the RN.- CharlesRGuide
dannieboiz wrote: We're getting to replace them all and no one said anything about NG but instead they're looking at Synology and QNAP.
I know next to nothing about the corporate environment and we couldn't be much more off topic... but I think this goes back a couple of generations. They were dormant far too long and let others bring to the table an interface (and or features) that surpassed them. And corporate wise it's not something that changes overnight... it took a relatively long time to become the prevailing view and it would take time to change regardless of it being valid or not for any specific generation.
I see the same thing on the consumer side. As an example at AVSForum mention NAS and a certain vendor's name is used almost in the way TiVo is. It virtually defines the category. It doesn't matter that on the low end models ReadyNAS (pretty much) out performs them and costs significantly less or the fact what makes it so much better than ReadyNAS are features you'll never use on models that you'll never purchase.
To a large degree it comes down to preconception. Certainly not in all cases but it creates a trend and one that's hard to buck. - mdgm-ntgrNETGEAR Employee RetiredAny of our current models can be joined to a domain. Still it is important especially for large purchases to make sure you are buying the right product for what you need.
Models such as Duo v2, 102 and similar models from other vendors come with ARM CPUs and low amounts of RAM. This may be fine, but you do need to evaluate whether it will handle the load you will put on it.
The 312 with its Intel CPU and 2GB RAM can handle a higher load. - FYI: I updated the 4200 to 6.1 then 6.2 w/o a problem. All 7 of my drives shows up with full capacity vs on 4.2 I was missing 1Tb.
4.2 didn't recognize my Cyberpower UPS but now it does.
So far, 6.2 is addressing all of my previous issues with 4.2 as well as 6.1 - KillerBobAspirantI am about finished running a complete (cold) backup of my Pro Pioneer, and will be installing 6.2 beta when done. I'll of course be upgrading to 6.2 immediately following that. It will be like getting a new NAS:)
As I understand it there may be an issue with spin-down and fan speeds. Are these issues still present, and are there any other biggies? - mdgm-ntgrNETGEAR Employee Retiredspin down and fan speeds should be fine.
- grimlochAspirantFan speeds seem to finally be working well on both of my Readynas Pros running 6.2. On 6.1.9 the fan wouldn't really kick in until they got to about 85°C.
Both have been upgraded to an Intel E6600 (the cooler version), btw.
Upgraded forked-daapd (iTunes server) that no longer crashes xbmc is also a welcomed edition:)
Sent from my Nexus 5 using Tapatalk - sgirardTutorHow long this updating should take if you already had the pro at 6.1.9? The reason that I am asking is because I updated via front view and my unit stuck in Booting... Updating firmware for last 30 min or so?
- mdgm-ntgrNETGEAR Employee RetiredIt shouldn't take that long. Perhaps try a reboot
