uniwow
Oct 25, 2013Aspirant
Archive bit backup incomplete
I'm trying to backup approximately 900 GB of files from a Windows 2008 Server to my ReadyNAS 102 using the Archive Bit. The credentials I've used on the ReadyNAS for the backup are correct and verifie...
Oct 25, 2013Guru - Experienced User
I am thinking that it might be running into a file that won't copy.
Can you try moving files to a temporary folder (off the backup path), and then try to slowly move them back?
Or maybe try copying the files on a different windows machine using robocopy (and the same credentials)?
You could also try setting the archive bit on all the files in the folder.
