uniwow
Oct 25, 2013Aspirant
Archive bit backup incomplete
I'm trying to backup approximately 900 GB of files from a Windows 2008 Server to my ReadyNAS 102 using the Archive Bit. The credentials I've used on the ReadyNAS for the backup are correct and verifie...
uniwow
Oct 27, 2013Aspirant
Thank you for your suggestions. I tried setting the archive bit on all files/folders, but it would not backup past that certain folder.
I created a new share on the NAS and manually copied the folders, which worked. I then wiped the files and tried the backup- it still quit in the same spot.
