hp532
Jun 08, 2017Aspirant
Are there any benefits to using home folders?
I am currently in the process of resetting my 314. When I originally set it up 3 years ago (fw 6.1/6.2), I decided that it was more sensible to create a share for each user rather than using home fol...
Sandshark
Oct 07, 2017Sensei
If you have a lot of user churn, then using the automatic home folders certainly makes it a lot easier on the admin. Otherwise, I also recommend you manually create folders for each user instead, especially if you use both local and ReadyCloud accounts for the same user. Note that they cannot have the same name as a user, but something like user1-home for user1 certainly works.
craer
Oct 07, 2017Aspirant
ya i get that i will have 10 users or so.
and yes i dont use local users>>>
i use my readycloud info so
exp: craer@craer.com
12345
insted of using a local user and password
so its like and is 1 account. idont see and nead to have a local and a readycloud account at the same time
- Marty_MOct 11, 2017NETGEAR Employee Retired
It does appear you want to use the same username and password for both local and readycloud account. We do not recommend doing since both will create a home share with the same name too and that will create a problem.
Marty_M
NETGEAR Community Team - Marty_MOct 16, 2017NETGEAR Employee Retired
Hello craer,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
