trilidar's avatar
trilidar
Attempting to 'Mirror' Entire C: Drive
I'd like to 'mirror' the entire C: drive from a Pro6 to an Ultra6, however nothing I've read (or found on the web) makes it even sound like a possibility.
Surely someone has done this before and can provide some pointers/tips, because I'm going nowhere fast. Heck, I can't even figure out how to properly 'format' the backup job itself.
Any help is greatly appreciated.
  • the short answer is you can't.
    the long answer is, on the pro, you can select drive c as the source, and the ultra as the destination, but this will put pro6/c in a *share folder* on ultra6. ie pro/c to ultra/backup/c
    there is no supported way to go from /c to /c, which is unfortunate because I'm sure alot of people would want that (including myself).
    you can create multiple share to share jobs, ie /media to ultra6/media
    obviously, all backup jobs are one way, there is no 'syncronization' or actual mirroring changes from both sides to the other.
    if your devices are in different locations, you should look at readynas replicate, whic is a paid addon from netgear, which makes remote backups much simpler (but not very cheap).
    if you are are looking for syncronization between devices, you can check out the egnyte local cloud product and see if it will work for you, however its not free and has a monthly service fee and other limitations.
  • StephenB's avatar
    I use one job for each shared folder to accomplish this - it works quite well. The first backup for each folder used NFS, then I edited each job to use rsync.
    Note with rsync there is an option which looks for missing files on the source, and deletes them on the destination. Normally I don't check that, every now and then I check it and run the backup jobs manually, just to clean out clutter. However leaving it unchecked gives you some protection from accidental deletions.
ProSupport for Business
