ClubChapin
Jul 21, 2013Aspirant
Auto Power On after Power Loss?
How do I set the Readynas to Power On after a power loss? It is very annoying that I cannot figure this out. It would be nice to be able to set it to "Power On", "Last State", or "Power OFF" after a...
ReadyAS
Aug 17, 2013Guide
mdgm wrote:
ClubChapin wrote: When my Duo and NV+ shut down with a power outage, they do not come back on, even at a programmed "switch on" time of day event.
That's because the hardware of those models does not support auto power on after power failure,
So, the x86 (e.g. RNDU4000, RNDP4000) supports auto power on, but there is NO OPTION to decide about power on (auto on or SIMPLY stay in off) - it's very irritating and I can't understand that approach to the matter.
If the auto power on is supported there should be an option to disable the functionality. Maybe is there any way to disable it directly in unix (not through Frontview interface)???
