Equinox1
Apr 07, 2019Guide
Automatic home folders on mac
Hi everybody,
I’m running a Pro 6 with OS 6.9.5, and I have several user accounts (mom/dad/daughter1/daughter2) and I would like to automount their home folder as a drive on the mac desktop whe...
Equinox1
Apr 07, 2019Guide
Thanks for the input, but I noticed that on the support article.
What should the share address be?
SMB://<readynas>/home ?
Apr 07, 2019Guru - Experienced User
No, SMB://<readynas>/mom (or whatever the user name is).
This only works if you are access the NAS with the user credentials for that account.
- Equinox1Apr 08, 2019Guide
So, there’s no way of doing a system-wide configuration that I can create for all users at boot-up?
- StephenBApr 08, 2019Guru - Experienced User
The home share name for each user account matches their user name, and requires you to access the NAS using either that user's credentials or the NAS admin account. If each Mac user name (and password) matches their NAS user name, then you might be able to automate it - though again, each user needs to log into the Mac for that to happen. So it can't be done at boot-up, it has to be automated at log on.
<Note, you could mount all the home shares - or the full data volume - using NAS admin credentials. But I wouldn't do that for this use case>.
Are you using a shared user account on the Mac? If you are, then I suggest creating a shared user account on the NAS, and use that credential on the Mac to access the network shares. Disable the home share feature (by turning off all network protocols on "home".). Then create public shares for each family member instead. Those can be all mounted at boot-up. But since you are using a shared PC with a shared log on, those shares won't be restricted (so all family members will be able to see them and access them). Of course the files on the PC work that way too.
The use-case is almost trivial:
-mom/dad/daughter logs in on the mac and sees immediately a personal drive on the right of the desktop.
Dad :-) would like to configure it at system level using a single line in the control panel for mounting shares, instead of having to do it for everyone of the 5 profile on the mac....
Another note: how can use local and ReadyCloud users? Do I need to use 2 home folders? The local user cannot share home folder with cloud one?
