EstivalG
Nov 13, 2015Aspirant
Automaticaly power off fail when manually powered on
Hello! I use a ReadyNAS 102 for nearly 2 years and since approxymatly 6 months, I got some power off problems. But first, the configuration: Ready NAS 102 with 2 Western Digital RED 3To Upd...
Nov 13, 2015Guru - Experienced User
Perhaps the NAS thinks some background task is pending. For example, a backup job that it mistakenly thinks is still in progress.
Start be looking for something like that. Also, check the drive SMART stats, and look for ATA errors. Another poster says they were responsible for his shutdown problem.
EstivalG
Nov 14, 2015Aspirant
Thank you for your reply!
_No backup job is set.Mainly because this NAS is used as a backup unit or to store non important files.
_No ATA error is reported by the unit.
I disabled as well the snapshots.
Another idea?
Thank you in advance.
- cpu8088Nov 14, 2015Virtuoso
try os6.4.1-T35 beta 3
check the changed log. perhaps this bug is fixed
"""[Beta 3 ] Fix issue with RN10x / RN2120 where the system may not power off fully."""
