EstivalG
Nov 13, 2015Aspirant
Automaticaly power off fail when manually powered on
Hello! I use a ReadyNAS 102 for nearly 2 years and since approxymatly 6 months, I got some power off problems. But first, the configuration: Ready NAS 102 with 2 Western Digital RED 3To Upd...
EstivalG
Nov 14, 2015Aspirant
Thank you for your reply!
_No backup job is set.Mainly because this NAS is used as a backup unit or to store non important files.
_No ATA error is reported by the unit.
I disabled as well the snapshots.
Another idea?
Thank you in advance.
cpu8088
Nov 14, 2015Virtuoso
try os6.4.1-T35 beta 3
check the changed log. perhaps this bug is fixed
"""[Beta 3 ] Fix issue with RN10x / RN2120 where the system may not power off fully."""
