Sandshark
Aug 31, 2022Sensei
Backup and restore of VPD file for legacy ReadyNAS running oS6
We have recently seen a rash of errors reported here on legacy machines upgraded to OS6 that are associated with a corrupt VPD (Vendor Product Data) file. This doesn't usually occur when the NAS is c...
tsdampier
Dec 07, 2024Aspirant
While i have not been to a linux command prompt in years none of these articles tell me how to mount the firmware mount location on the dead NAS??
I have been able to telnet in to the dead NAS but i can't for the life of me figure out what is the proper command to mount the drive so I can copy the VPD file from another NAS.
dmesg | grep -i 'disk'
[ 0.000000] RAMDISK: [mem 0x7f6a6000-0x7fffffff]
[ 3.168449] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.486127] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 3.788597] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 4.088025] sd 3:0:0:0: [sdd] Attached SCSI disk
[ 5.146077] sd 4:0:0:0: [sde] Attached SCSI disk
[ 5.405128] sd 5:0:0:0: [sdf] Attached SCSI disk
[ 8.367613] scsi 6:0:0:0: Direct-Access SanDisk Cruzer 7.01 PQ: 0 ANSI: 0 CCS
[ 8.368022] scsi 7:0:0:0: Direct-Access SMI USB DISK 1100 PQ: 0 ANSI: 0 CCS
[ 8.379228] sd 6:0:0:0: [sdg] Attached SCSI removable disk
[ 8.380757] sd 7:0:0:0: [sdh] Attached SCSI removable disk
# mount -t tmpfs -o size=2048M tmpfs /media/ramdisk
# mount
rootfs on / type rootfs (rw,size=2013636k,nr_inodes=503409)
proc on /proc type proc (rw,noatime,nodiratime)
sysfs on /sys type sysfs (rw,noatime,nodiratime)
devpts on /dev/pts type devpts (rw,noatime,nodiratime,mode=600,ptmxmode=000)
# cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount pt> <type> <options> <dump> <pass>
/dev/root / ext2 rw,noauto 0 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
tmpfs /dev/shm tmpfs mode=0777 0 0
tmpfs /tmp tmpfs defaults 0 0
sysfs /sys sysfs defaults 0 0
some simple command to find the location where the corrupt VPD file is would be helpful 🙂
