wnhcorp
Jul 02, 2012Aspirant
Backup between two nas 1100 is very slow
The company I work for has two nas1100 with 4.1.8 one is live and other is backup. We do the back through rsync at night when everyone is off the live nas. The two nas are connected through crossove...
mdgm-ntgr
Jul 02, 2012NETGEAR Employee Retired
No need to use a crossover cable for a direct-connect. An ordinary ethernet cable works fine as the NIC is auto-sensing.
Rsync has to compare the file on the source and destination then it only transfers the changes to the file across. This can make the job appear to be a lot slower than it really is. Also the 1100 has a slow CPU.
What speed do you get if you use say a NFS backup job?
How much RAM is in the 1100 units?
When did you purchase the 1100 units?
