wnhcorp
Jul 02, 2012Aspirant
Backup between two nas 1100 is very slow
The company I work for has two nas1100 with 4.1.8 one is live and other is backup. We do the back through rsync at night when everyone is off the live nas. The two nas are connected through crossove...
wnhcorp
Jul 05, 2012Aspirant
No need to use a crossover cable for a direct-connect. An ordinary ethernet cable works fine as the NIC is auto-sensing.
Rsync has to compare the file on the source and destination then it only transfers the changes to the file across. This can make the job appear to be a lot slower than it really is. Also the 1100 has a slow CPU.
Hello,
Thank you fro the response back. I tried regular ethernet cable as well and on the ethernet 2 port interface I do see a 1000mbit connection. Below are the answers to your questions
What speed do you get if you use say a NFS backup job?
I get about 11 mb/s sometimes even faster. Even transferring file from nas to my pc I get 13mb/s bursts upto 21mb/s
How much RAM is in the 1100 units?
I beleive 512mb, I think thats what they came with. Is upgrading the ram as simple as just swapping out the memory?
When did you purchase the 1100 units?
The units are about 3 yrs old. However they do have a new hard drives. The reason that I even noticed the transfer rate is because I upgraded one of them with 4 sets of 2TB hard drive (hdd are 7200 rpm 64mb cache), and when I went to transfer everything from the other nas to the upgraded hdd nas.
Thank you again for trying to help.
Hello,
