Ray2
Jan 02, 2022Luminary
Backup failure issue
OS 6.10.6 File Backup from a folder source in NAS to PC-USB connected drive (remote) destination works on first time run only Subsequent runs fail: "Error backup job <NAME>. Destination is re...
- Jan 02, 2022
Ray2 wrote:
Subsequent runs fail: "Error backup job <NAME>. Destination is read-only or files/folders could not be created. Check if these files or folders meet the destination file system limitation"
This is almost certainly an issue with the PC. In general, there are two sets of permissions that need to be set to read/write. One is the network access to the destination share, the other are the file permissions in the destination folder. Since the first run seems to work ok, the issue is likely the file permissions.
There is another way to accomplish your goal - which is to use PC backup software to back up the NAS share to the PC. So you might want to look into that. It's more secure, especially if the PC is a laptop that is sometimes connected to other networks. FreeFileSync is one of several options.
Jan 02, 2022Guru - Experienced User
Ray2
Thank you! Good thoughts all! Happy New Year!
