whartonw
Oct 16, 2021Guide
Backup Job on Ultra
StephenB Sandshark Can you point me somewhere that explains the proper format for the name of a computer from which I am trying to backup to the Ultra NAS, running 4.2.31. I have tried the c...
- Nov 14, 2021
200 pin. 667 (PC2-5300) and 800 (PC2-6400) mhz both work. I don't know the speed of the stock RAM (never owned an Ultra) - you could open up your unit can google on the part that you currently have installed.
Oct 16, 2021Guru - Experienced User
If you are using Windows backup, then you need to create a network share on the PC (for the folder you want to back up).
- whartonwOct 16, 2021Guide
Trying to be brief, I left out relevant details. Apologies.
I'd like to use a backup job on the Ultra to pull a copy of data from a Mac computer. In setting up the job, I am running into problems pointing the Ultra to the Mac. I don't have any trouble pushing from the Mac to the Utra, and I don't have any trouble with my 424 pulling from eiher the Mac or Windows machine. This is the first time I've tried to pull with the Ultra (or any OS 4 NAS); clearly the naming/addresses conventions are not the same.
Thanks.
Wharton
- StephenBOct 16, 2021Guru - Experienced User
whartonw wrote:
This is the first time I've tried to pull with the Ultra (or any OS 4 NAS); clearly the naming/addresses conventions are not the same.\
I am thinking it's more likely that the Mac SMB server doesn't include SMB 1 (which is what 4.2.x NAS use).
See if you can set up the share to use NFS.
