whartonw
Oct 16, 2021Guide
Backup Job on Ultra
StephenB Sandshark Can you point me somewhere that explains the proper format for the name of a computer from which I am trying to backup to the Ultra NAS, running 4.2.31. I have tried the c...
- Nov 14, 2021
200 pin. 667 (PC2-5300) and 800 (PC2-6400) mhz both work. I don't know the speed of the stock RAM (never owned an Ultra) - you could open up your unit can google on the part that you currently have installed.
whartonw
Nov 13, 2021Guide
"DDR2 SODIMM RAM" doesn't appear to be a sufficient spec for a 2GB memory module, but that's the only spec I have managed to find. This is in the hdw manual for the unit.
200 pin? Unbuffered? 800 or 667MHz? Anything else?
Thanks
ww
Nov 14, 2021Guru - Experienced User
- SandsharkNov 14, 2021Sensei
It's basic PC RAM -- unbuffered, non-ECC.
