lestes
Mar 10, 2015Aspirant
Backup NAS 102 via LAN Using USB on Netgear R7000 Router
Hello I'm using a ReadyNAS 102 and I have a USB 3.0 WD Portable Hard Drive that I have used for backup from the front USB of the 102. It works fine but is a manual process. Across the house and o...
Mar 10, 2015Guru - Experienced User
The R7000 shares the drive using CIFS/SMB. So you need to choose the "windows" protocol option for the destination in the RN102 backup job. The default Router sharename is USB_Storage. So setting the host as 192.168.1.1 and the path as USB_Storage\NAS Backup ought to work.
