TT_DE
May 08, 2017Luminary
Backup NAS 2 USB HDD stops unforeseeable after 500 GB
Having bought a new usb hdd 5 TB a few months ago and set up this device as backup device for the NAS 516. The first full backup worked fine. During the last weeks the nas run incremental backups da...
- May 09, 2017
Having checked the whole setup including format and cable I could identify a malfunction of the power adapter of the hdd which caused the backup errors.
There has been a loose contact in the 12 volt power adapter. I changed the adapter and the backup run properly and ended succesful without interruption.
Surprisingly the brand new power adapter was delivered with a malfunction.
Thank you to you all for your helpful and kind recomendations - I have learned a lot regarding doing backups properly.
May 08, 2017Guru - Experienced User
Usually this happens when people don't eject the USB drive when the backup completes. Do you have auto-eject set on the backup job?
Also, I am thinking this might be an SMR drive. Do you know if that is the case?
TT_DE
No, haven't activated auto-eject. Haven't this activated in my other backup job either. For this job I am using the same model of usb hdd and it works fine.
I am using the same type of usb hdds for the two backup jobs: 5 TB WD Model WDBWLG0050HBK-EESN
I bought two of them, one last year, the recent hdd which causes the problems in February this year.
My understanding is - not 100 % sure - that the WD 5 TB Elements is NO SMR drive. Nothing mentioned re SMR neither in the invoice of the hdd nor on the packing. I have read that that SMR drives have to deal with massive reduction of data transfer rate during longer data transfer processes.
- StephenBMay 08, 2017Guru - Experienced User
I understand that it works most of the time. But turn on auto-eject - your symptoms result from the "dirty" bit being set on the USB drive.
The reason I mentioned it is that SMR drives need to do a lot of post-processing when you write data (because when you write track X, it corrupts track X+1). That could be a contributing factor.
But I also believe that the WD elements is PMR.
- TT_DEMay 08, 2017Luminary
StephenB wrote:
TT_DE wrote:No, haven't activated auto-eject. Haven't this activated in my other backup job either. For this job I am using the same model of usb hdd and it works fine.
Thx for the hint. Turning on auto eject means that I have to restart the NAS daily to reconnect the USB HDD ?
Otherwise I could not run incremental back up daily. could I?
But how could this "dirty bit" occur during a running backup? Backup starts properly and suddenly stops after having transferred more than 500 GB?
TT_DE wrote:My understanding is - not 100 % sure - that the WD 5 TB Elements is NO SMR drive.
Thank You.- TT_DEMay 08, 2017Luminary
Seems to be the identical issue like this one: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/After-backup-Destination-is-read-only/m-p/960340#M10182
