RN104Owner
Feb 05, 2015Aspirant
Backup not complete again
I purchased my RN104 this week. It is a very nice NAS box for its price. It came with OS6.2 out of the box. I updated it to 6.22 then set it up with 3 - 4TB drives in raid5 and let it run over night ...
krgoodwin
Mar 28, 2015Apprentice
I found your source path suggestion solved my inability to get the backup to execute. I was following the Netgear documentation (useless) and the youtube video by Mammoth Jerk titled "How to set a Backup with a Netgear ReadyNAS step by step guide". For the path source, he uses only the source folder share name but I would get "Access denied: invalid username or password. Code 7077010013" when I tested the connection. I don't use a administrator password on my computer so I thought that might be the problem although Mammoth Jerk indicated it wouldn't be a problem as long as the Network Access and Sharing password settings were correct. Since some users indicated that the backup would execute even though the "test connection" failed, I attempted to run the backup job but it failed saying "source cannot be mounted on the system". Changing the source path using your suggestion resulted in a successful test connection (the entire Windows path without the leading / as you suggested) and the backup job would successfully complete. I have one last problem however - nothing was backed up to the destination share folder. The backup job completes in less than two seconds. Since I've already spent 3 days attempting to get this to work, I guess I still need to attempt all permutations and combinations (read as trial and error). But a BIG thanks for getting me one further step down this painful path. Ken Goodwin, Houston.
