mattmcl1
Jan 01, 2008Aspirant
Backup not working
I haven't run my regular backup jobs for a month. In that time I have: Replaced disk #1 after failure & resynced Replaced disk #2 after failure & resynced Upgraded to version 4 of FrontView N...
ewok
Feb 19, 2008NETGEAR Expert
fourthturn wrote: Can you tell us what fixed their problems? If their symptoms were the same, maybe the fix is the same for us.
One had the wrong syntax in the path field for the backup job, one had a DNS problem, and another user in another thread with a similar issue updated the firmware on his non-ReadyNAS device which resolved the problem.
