mattmcl1
Jan 01, 2008Aspirant
Backup not working
I haven't run my regular backup jobs for a month. In that time I have: Replaced disk #1 after failure & resynced Replaced disk #2 after failure & resynced Upgraded to version 4 of FrontView N...
bztmzt
Mar 27, 2008Aspirant
ewok wrote:
bztmzt wrote:
Error encountered copying data from remote source path //[SERVER]/Public ==> /DATA//Public due to permission denial on one or more files.
cp: cannot open '/job_004//./Administration/IT/Licences.xlsx' for reading: Permission denied
cp: cannot open '/job_004//./Design/Chemical Data Sheets/Sodium Hydroxide 30%.pdf' for reading: Permission denied
cp: cannot open '/job_004//./Design/Chemical Data Sheets/Sodium Nitrate crystals.pdf' for reading: Permission denied
If you connect to the source share with Windows Explorer using the login credentials you gave the backup job, are you able to access those files?
yes not a problem what so ever.
I can also back them up using the Archive bit.
I have two NAS devices on slightly different firmware's both on 4. i haven't set the second NAS backup yet... testing over the weekend.
