mattmcl1
Jan 01, 2008Aspirant
Backup not working
I haven't run my regular backup jobs for a month. In that time I have: Replaced disk #1 after failure & resynced Replaced disk #2 after failure & resynced Upgraded to version 4 of FrontView N...
ewok
Sep 19, 2008NETGEAR Expert
If you feel more comfortable with a backup before upgrading the firmware, here are a couple of things you can try:
1. I'm not sure what your backup destination is, but if it's a PC, you can do a simple drag and drop to back it up.
2. I believe that version of the firmware had occasional problems with shares that did not require a username and password to connect. Try adding a username and password to the destination share and adjusting the backup job accordingly.
Otherwise, you can just do the upgrade, it should be safe.
