mattmcl1
Jan 01, 2008Aspirant
Backup not working
I haven't run my regular backup jobs for a month. In that time I have: Replaced disk #1 after failure & resynced Replaced disk #2 after failure & resynced Upgraded to version 4 of FrontView N...
jimmyg1
Oct 17, 2008Aspirant
Hi,
I too am experiencing the same problem as many of the posters on here. I am trying to backup my ReadyNAS Pro to an Iomage StorCenter. I have tried to use the root as the source as well a single directory. Test connection works, but it is unable to access a remote path. I've used the drive name as well as the ip address, and changed my slashes back and forth. My most recent log is below. I can arrange remote access, if desired.
INCREMENTAL Backup started. Fri Oct 17 14:52:59 PDT 2008
Job: 002
Protocol: cifs
Source: [Network]/
Destination: //SCRATCHY/Krusty_Backup_2
Backup failed. Fri Oct 17 14:53:00 PDT 2008.
Reason for failure:
Unable to access remote path //SCRATCHY/Krusty_Backup_2.
Job: 002
Protocol: cifs
Source: [Network]/
Reason for failure:
