erynhopekb
Sep 01, 2015Follower
Bad Drive Replaced, Not Resyncing
I have a four drive ReadyNAS in a RAID5 array. I replaced a failing hard drive this morning but the array is not resyncing. It's using xraid and firmware 6.1.9, drives 1,3, & 4 are blue and drive 2 (...
Sep 01, 2015Guru - Experienced User
What model drive did you remove (and what model was the replacement)?
FWIW, 6.1.9 is very old. After you get past this you should upgrade it. However, don't mess with that now.
