erynhopekb
Sep 01, 2015Follower
Bad Drive Replaced, Not Resyncing
I have a four drive ReadyNAS in a RAID5 array. I replaced a failing hard drive this morning but the array is not resyncing. It's using xraid and firmware 6.1.9, drives 1,3, & 4 are blue and drive 2 (...
S_Lee
Sep 08, 2015Aspirant
Similar situation
RN2120 - 4 Drives - 4TB each (same make/model)
Firmware - 6.2.4
RAID5
Drive 1 went bad and got a RMA replacement, same make/model.
Tech installed the new drive on Friday (Sept 04) and today (Tues 09-08) it still shows as RED. Log file does not show any info that it even attempted to resynch.
Had tech remove new drive 1 and re-seat it again. status has not changed.
According to this procedure http://kb.netgear.com/app/answers/detail/a_id/23456 - RN2120 is completely hot swappable and does not require any input from the user or reboot.
Please advise.
- StephenBSep 08, 2015Guru - Experienced User
What model drives are you using?
You are correct, the unit supports hot-swapping. You can use the support "live chat" option, support can likely figure out the issue faster than the forum.
- S_LeeSep 08, 2015Aspirant
Western Digital
4.0 TB
WD4000FYYZ-01UL1B0
I think support is a good next stop.
They will want a full log download, so you might as well do that now.
I guess it could be possible that the replacement drive I received is defective too. It is a refurbished unit according to the receiving slip.
How can we test the replacement drive? Can my tech could pull the replacement drive and connect it to a PC to see if it detects the drive?
- vandermerweSep 08, 2015Master
Yes you can do this and use WD lifeguard to test the drive thoroughly.
Is there a backup?
Have you attempted at least one reboot?
