erynhopekb
Sep 01, 2015Follower
Bad Drive Replaced, Not Resyncing
I have a four drive ReadyNAS in a RAID5 array. I replaced a failing hard drive this morning but the array is not resyncing. It's using xraid and firmware 6.1.9, drives 1,3, & 4 are blue and drive 2 (...
Sep 08, 2015Guru - Experienced User
What model drives are you using?
You are correct, the unit supports hot-swapping. You can use the support "live chat" option, support can likely figure out the issue faster than the forum.
