erynhopekb
Sep 01, 2015Follower
Bad Drive Replaced, Not Resyncing
I have a four drive ReadyNAS in a RAID5 array. I replaced a failing hard drive this morning but the array is not resyncing. It's using xraid and firmware 6.1.9, drives 1,3, & 4 are blue and drive 2 (...
S_Lee
Sep 08, 2015Aspirant
I will have my tech pull the drive out again and use the WD Lifeguard to test it tomorrow morning (he's already gone for the day).
No we have not rebooted the ReadyNAS yet.
Sep 09, 2015Guru - Experienced User
I agree a reboot is good idea.
Often removing and then reinserting the drive works as well.
I believe the NAS uses the SMART self-test, so make sure that one is run (its also the shortest).
- S_LeeSep 09, 2015Aspirant
Ran diagnostics using Western Digital Lifeguard - Bad Sectors detected.
Replacement Drive is DOA.
Will contact Support and get another replacement RMA. Hopefully the next one will work.
