KrissKross
Jul 20, 2011Aspirant
Bad transfer speed after Firmware upgrade
Hey Guys I'm really annoyed about my transfer speed after I upgrade to the firmware 4.2.16. I have a Ready NAS Ultra 4 and I copied my movie files from my PC (Windows 7) with speeds up to 50 MB...
mdgm-ntgr
Jul 20, 2011NETGEAR Employee Retired
You need Cat5e or higher. Cat5 isn't good enough.
Even if you haven't touched your hardware it's still possible to have a coincidental problem and a good idea to try to rule that out. I would suggest trying what I suggested above.
You could try installing your addons over the top of themselves and see if this makes a difference. It has been known to make a difference sometimes.
I believe your disks aren't on the HCL. Disks not on the compatibility list may/may not work. It's possible a firmware update could cause issues with disks that are not approved for use with the ReadyNAS.
Edit: Checking for a bad disk using the "Disk Test" boot option using the boot menu (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) could also be a good idea (I would try this after other suggestions)
