KrissKross
Jul 20, 2011Aspirant
Bad transfer speed after Firmware upgrade
Hey Guys I'm really annoyed about my transfer speed after I upgrade to the firmware 4.2.16. I have a Ready NAS Ultra 4 and I copied my movie files from my PC (Windows 7) with speeds up to 50 MB...
whocares256
Jul 21, 2011Aspirant
I have the same problem I bought the ReadyNas Ultra 2 Plus and was getting a constant 85MB/s in RAID 0. I changed to RAID 1 and After the firmware update i only get 19 to 20MB/s.
Current drives are 2 x Seagate ST32000542AS
Logs Below.
[2011/07/21 00:37:04] Factory default initiated by button!
[2011/07/21 01:03:39] Updated from RAIDiator to 4.2.15.
[2011/07/21 00:53:22] Updated from RAIDiator 4.2.15 to 4.2.18.
I updated the firmware because i was getting an overheating warning on the CPU fan. We should be able to downgrade back to the previous version.
UPDATE: Talked to Netgear support and did a config reset and I was getting 85MB\s again. What changed was the network settings. Default is jumbo frames disabled and MTU set to 1500 for the Ultra 2 Plus.
Logs Below.
