KrissKross
Jul 20, 2011Aspirant
Bad transfer speed after Firmware upgrade
Hey Guys I'm really annoyed about my transfer speed after I upgrade to the firmware 4.2.16. I have a Ready NAS Ultra 4 and I copied my movie files from my PC (Windows 7) with speeds up to 50 MB...
KrissKross
Jul 22, 2011Aspirant
whocares256 wrote: UPDATE: Talked to Netgear support and did a config reset and I was getting 85MB\s again. What changed was the network settings. Default is jumbo frames disabled and MTU set to 1500 for the Ultra 2 Plus.
Hey Guys
Have changed my MTU from 9000 to 1500 and are back at 50 Mbps!!! Don't belive it. Didn't change anything while upgrading, but only with this change everything is perfect again.
Update: Something is strange. If I change the MTU manually to 1500 the transferspeed is high. But when the values are automaticly set after a reboot the MTU value is always higher and the transfer speed much lower. I didn't have this issue before the firmware upgrade!
